Help with removing smog stuff and some newb questions*pics*
Discussion in 'The Garage' started by 85mudblazin, Sep 22, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My quest is to have a clean engine compartment with only the essentials to make the engine run.
    First up is to take off all the smog crap, I plan to get a aluminum manifold to do away with all the smog ports and such.
    But I want to remove the charcol canister at the moment and anything else that yall can spot in the pics that can be removed.
    I have figured I can take off most of the canister lines except 2 that I am wondering about. Here in the pic the line that the white arrow is pointing to, can it be removed or do I need to take it off and cap off the inlet in the carb??
    The black arrow shows the line that runs to the manifold but t's off and has a line running to some other unhooked smog stuff. I can just run it straight fromt he carb to the manifold correct??
    Also in the last pic the white arrow points to the gas tank breather hose, can I just put a breather on it like you would on a diff breather??
    Keep in mind I know jack diddly squat about engine componenets, so fell free to tell me if anything looks fubared.
    -Chris
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    It is illegal to remove those parts, its call Tampering. :(
    Besides that if they are in decent working order they do not
    hurt HP, or low end Torque. :doah:
    Learn how they work, and our Air/planent will thank you. :D
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    This is a trail only rig, did you not ready what I wrote??? I said I want just the essentials to run the engine. I dont want all this extra crap in there. There is no smog pump and half of the smog lines are not connected to anything so there is no point in keeping any of it.
    So anyone know what all i can take off??
  4. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    Sounds like Tree-Huggin Al Gore is a member of the forum here :D
  5. dyeager535
    26,979
    Of all of them, leave EVAP, and that is simply because your tank is thus not really "vented" anywhere that water could get in. Venting a tank without EVAP is pretty difficult to do, and I have yet to come up with a better vent system.
    AIR and EVAP are probably the two most complex pieces, but on the 80's carbed stuff, your vacuum advance, lockup, EGR and probably some other stuff add clutter and vacuum switches compared to early setups, but aren't exactly necessary.
    Of course, if it runs good now, taking that stuff off will more than likely cause problems, that's about a given.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I really just want to get the charcol canister out of the way since I will be removing the inner fenders pretty soon.
    What is everyone doing that has taken theres out and has a gas tank still??
  7. dyeager535
    26,979
    I'm running an early vented gas cap, but so far (for me) those have been impossible to find new.
    I wish I would have left the cannister in mine. With the later ECM controlled EVAP purge, I believe some of the vacuum lines are gone that are shown in your picture.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep got to be a tree hugger if you like breathing clean air thats for shure :rolleyes: :rolleyes: :rolleyes: :mad:
  9. Executioner
    Feb 22, 2000
    1,530
    -Chris
    No i can't read or right, only polut on the trail
  10. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    first pic, pull it and plug the carb, second, black arrow where?, third, yes, but I reccommend running a hose off the vent tube to as high up the core support or firewall as you can, then putting a breather on the end of the hose
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If it runs correctly I'd honestly leave it be. I know it's a lot easier to work in an uncluttered engine compartment but the extra time you spend working around stuff would probably be nothing compared to the time you'd spend trying to make the truck run right if something got messed up.
    That being said...Executioner, go look up statistics on the levels of hydrocarbons and airborne pollutants released by lawn mowers every year, and then find statistics for four stroke OHV's like ours.
