Help with rotor!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80K5, Feb 26, 2002.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Hey, I need to get a new front driver side rotor. I was just wondering would any 10 bolt front axle work for the rotor and would a dana 44 rotor bolt right up?
    Just to let you know the axle is out of an 87-91 chev
    Stuck? Yep, I'm always stuck!
    Steve!
  2. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    I am talking about a brake rotor just incase that wasn't clear.
    Steve!
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i just swapped from a 85 10 bolt to a 79 44 and it worked fine
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Assuming we are talking about a 6 lug rotor, the hub and rotor are the same for the Dana 44 and the 10 bolt. There was a change in the spindle starting in 1977. GM went to a larger outer bearing. You can however still use the hub/rotor assembly from the earlier years as long as you change the outer bearing and race.
    1989 blazer, 383 stroker, D44 / 14FF, 4.56, locked, 35 BFG mud
    Scott
  5. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Thanks for the info!
    Steve!
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Hey Steve, is your truck 8 lug? The Dana 44 and 10 bolt 8 lug stuff will interchange as well but not all years.
    Scott
  7. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    No mine is a 6 lug. Thanks for the info everyone. Finally found someone with some spare rotors for me!
    Steve!
