Help with some engine quesions(heads)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grindkings, Dec 27, 2004.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    This is a new question but same theme. Being that i'm building a new motor. It will be TBI. I'm putting a Holley 670 CFM throttle body and a holley pro-jection manifold. I'll probly put roller rockers as well. My question is...since my motor will be TBI, do i need to stay with TBI Heads(like the one that came stock, and just have them rebuild and ported) or will any heads work fine? Heads are VERY expensive:mad: so i want to go the best route posible. Thanks, -regards brian.
  2. dyeager535
    26,982
    191
    No you don't have to stick with TBI heads. As cast, they are garbage.
    The problem is that you will be dealing with the different intake bolt pattern, so something along the lines of some pro-toplines will be a good bet.
    I'm not sure about the torquers, etc., but good heads don't HAVE to cost a lot of money.
    There's a lot to be said of the Vortec head chamber design, if you can get that chamber, in a head with your intake bolt pattern, you will be doing good. Just have to research, unless someone knows the part number for the above described off the top of their head.
    If you rebuild stock heads like they should be for a new motor, (new valves, springs, checked/straightened, seals, not including studs if required) they will likely cost you MAYBE $1-200 less than a set of brand new heads, which will be better in the first place.
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    Thanks abunch. I just talked to a buddy of mine and he said he might have some TBI heads off a 1992 GMC. So i'll look into those. Does anyone know the bolt pattern on a Holley Pro-jection manifold. Thants what i'm building around. Regards- Brian
  4. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I used Vortec heads and an Edelbrock Performer vortec intake with an adapter plate that let me bolt the TBI to it.
  5. aj johnson
    aj johnson 1/2 ton status
    Nov 2, 2004
    232
    Idaho Falls, Idaho
    This route has my vote... vortec heads are the BEST you can get for a budget...
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I know the Holley projection is supposed to be a retrofit to old engines so it has the old carbed heads bolt pattern.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    What kind of manifold are you buying? You dont need a TBI manifold with Projection. Holley makes a bunch of different manifolds for projection. Or you can get an adapter plates to bolt the ProJection TB on any manifold you want. It is a very adaptable system.
    I definatly would not use TBI heads or pay money for them when you can get a lot better head. Rebuilding and porting a set of TBI heads well cost you just as much or more as buying a set of aftermarket performance iron or Vortec heads.
  8. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    So what you are say is that like 92` tbi heads won't bolt up to the Helley projection ?
  9. dyeager535
    26,982
    191
    Just depends on the intake bolt pattern of the pro-jection manifold.
    TBI heads have all eight corner bolts at an angle, just like all previous SBC.
    However, the CENTER intake bolts on *TBI* heads are vertical. There are 4. Older SBC's had the center 4 angled just like the corner ones.
    There are ways to work around these issues, but if you haven't bought parts yet, you might as well buy matching components in the first place, and save yourself time and effort on install.
    Of course, getting better heads that match up to whatever intake you decide to run, is a fine idea as well.
    "Best route" as you say, will be to spend money now on good components, instead of beating yourself up later for wasting money on junk, like stock TBI heads.
  10. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    vortech heads
    the v-tech heads are just as good as the old camel humps . and with the 1.94in/ 1.5ex valves thay make lots of tourqe down low. just have the heads worked up for the needed biger springs(stock no good with big cams) to fit and bolt on and go.
    p.s. thay are 64cc chambered heads
  11. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    You can drill the center bolts of intakes to fit either head pattern rather easily.
  12. dyeager535
    26,982
    191
    Just as good? Try superior in about every respect. :)
