Help with SPECS on my 85 Blazer
Discussion in 'The Garage' started by Trailboy, Mar 14, 2006.
  1. Trailboy
    Trailboy Newbie
    Mar 14, 2006
    4
    Orlando-Apopka
    Hey there, I am out of town, and trying to get measurements on the wheelbase of my 1985 4x4 Full size blazer to get it onto a tow cart. I have 33" tires. I need to know if anyone knows the weight of a blazer (I am out of town so I can't look in my manual), and I am needing the front to back tire distance axle to axle center, and the outside tire to outside tire distance across the vehicle. Anyone ever moved one on a BUDGET RENTAL full trailer behind a moving truck? It is out of their specs, but the car tower will hold 4200 lbs, and one called an ACC is 15.5 ft long for wheels, and another is called TCC which is 16 ft. I have to move across the country this weekend form Chicago to Florida, and the best shipping rate was like $850 to ship it. Way too much. The car tower is $320 and I have to confirm the dolly before I get back home to Chicago this weekend which is when I am moving to Florida. Any help on specs would be greatly appreciated!
  2. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
  3. Trailboy
    Trailboy Newbie
    Mar 14, 2006
    4
    Orlando-Apopka
    Details clarification?
    Can you tell what the axle to axle length is? Is it 104 inches? I can't quite tell from the other posting. It also looks to be 73 inches outside to outside of the vehicle. Can anyone tell if that is correct? I zoomed in but it got foggy. GVW looks to be 6100 lbs. If the capacity is 3750, is the difference the tow weight of the vehicle? I can't tell from this, and really need this piece of info. Seems there is the limit on weight that the car carrier can carry.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Wheelbase is 106.5"
  5. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Here are the specs on an '87 model which is a little clearer.
  6. Trailboy
    Trailboy Newbie
    Mar 14, 2006
    4
    Orlando-Apopka
    Tare Weight
    Anyone know the TARE weight of the 1985 blazer? They don't seem to keep it in the specs. I have a trailer that will hold 4200 lbs. I need to konw the 4x4 weight with a 5.0L engine.
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    1885 Blazer/Jimmy base models were 4462 curb weight (diesels were 4846). That's with no passengers.
  8. Trailboy
    Trailboy Newbie
    Mar 14, 2006
    4
    Orlando-Apopka
    I wonder if I took the back seat out, kept it low on fuel, and took out everything possible I could put it on the 4200 lb trailer that budget offers with the rental to drive it cross country. Any ideas? I have the 305 engine in it. That would take a few pounds off also...
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    you can fidn a lot of these info in the specs section in ck5.com
    @ http://www.coloradok5.com/specs.shtml
    Year: 1985Production Total: 40,011Base Price: 11,223Weight: 4,462Wheel Base: 106.5 in.
    Fuel Tank Capacity: 94 liter (24.83-gallon)/117 liter (31-gallon)
    Length: 184.8 in.Height: 73.4 in.Std. Engine, (net HP): OHV Six-cylinder 262 cid. (155) @ 4000 rpm
    Opt. Engine, (net HP): OHV Eight-cylinder 305 cid. (150) @ 4000 rpm
    OHV Eight-cylinder 305 cid. (160) @ 4400 rpm
    OHV Eight-cylinder 350 cid. (160) @ 3800 rpm
    OHV Eight-cylinder 350 cid. (165) @ 3800 rpm
    OHV Diesel Eight-cylinder 379 cid. (130) @ 3600 rpm
    OHV Diesel Eight-cylinder 379 cid. (151) @ 3600 rpm
    Rear Axle: GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 28 Spline)
    Front Axle: GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 28 Spline)
    Transmission (M): SM318/SM326/SM330/T-89A/T-150 3 spd. (2.47-3.50:1 First Gear)
    SM465 4 spd. (6.55:1 First Gear)
    Transmission (A): TH350 (2.52:1 First Gear)
    TH700-R4 (3.06:1 First Gear)
    Transfer Case (M): NP208 (2.61:1 Low Range)
    Transfer Case (A): NP208 (2.61:1 Low Range)
    Notes: The 1985 Blazers had much wider body color panel between upper, and lower grilles, and the grilles had only a single horizontal bar intersected by seven vertical bars. The headlight housing had more of a vertical look than last year's, although the rectangular lamps were stacked atop each other again. An amber-colored parking lamp was standard on the bottom, but when halogen high-beams were ordered, the parking lamps moved behind the lower grille.
    Blazers featured a steel half-cab with an integral roll bar built into the steel front compartment roof and lock pillar structures.
  10. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Here is another source:
