Help with spring bushings
Discussion in 'The Garage' started by sandawgk5, Oct 1, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    Kitsap County PACNORWEST
    I am going to replace my spring eye busings with poly when I get my springs. They are used that is why I am replacing them and the fronts had to be burned out so they def need replacing :D . My question is do 56s and 52s use the same spring eye bushings or do I have to order 1/2 ton fronts and 3/4 ton rear bushings. Also where is a good place to get said bushings I am not sure if I really want greasable not sure if they are needed.
