Help with spring eye bolts
Discussion in 'The Garage' started by sandawgk5, Dec 4, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I did a search and found the forward eye of the front springs is 9/16"X5" and the rear bolts on the front springs including the frame are 7/16"X5". Question I got is I am putting after market 4" lift springs in the front if they ever get here and the DIY4X flip in the rear with stock 56s. What bolts do I need for all 6 locations 3 front and 3 rear. The shackles I have for the front are 4.5" and have 1/2" holes and the rear shackle is 6" with 1/2" holes. Any help is appreciated.
    Ira
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the rears on my K10 and my C10 were both 9/16 x 4.5, i used 5s because they were easier to find and worked just as well.
  3. sandawgk5
    Oct 28, 2003
    6,881
    So I can drill out the rear shackles and use 9/16 on all the rear bolts. What do I have to do to run 1/2 or 9/16 in the rear 2 bolts on the front springs.
    Ira
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    New bushings, and drill out your shackles
  5. sandawgk5
    Oct 28, 2003
    6,881
    Do they make bushings for 9/16 or 1/2 bolts I would prefer 9/16 just for ease of replaceability ya know less spares to keep.
    Ira
  6. readymix
    May 30, 2004
    6,706
    26
    Sure do, My truck is 9/16 all the way around
  7. sandawgk5
    Oct 28, 2003
    6,881
    Sweet I live like a block from National Spring I will see if they have any.
    Ira
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    shouldnt have to drill anything out. all of the trucks i've torn apart have been 9/16" all the way around on the rear.
  9. sandawgk5
    Oct 28, 2003
    6,881
    I have Kert's shackle flip with his 6" shackles on his site it says they are drilled for 1/2".
    Ira
