Help with starter!?!?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebel222, Jan 3, 2001.
  1. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    I have a 1980 K5 with a goodwrench 350 in it. When I bought it, there was a terrible sound with the starter. You know the old truck sound without shims in it. Well the guy told me he just hadn't crawled under there to put the shims in. Well I decided to and the darn thing was twice as far from the fly wheel as it should be. I know you can put 1/2 shims in to move it closer, but that doesn't move it near far enough. I read somewhere there are 2 different size flywheels. Could I have the wrong starter? If I do how do I get a starter for a goodwrench engine? How do I identify this engine when looking for parts for it? Thanks
    Logan
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    sometimes you have to file the mount down to get it close
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Where do ths shims go? I put a new starter on today and didn't use any, but there was a shiny thing about 2-3" long in the box with a hole on each end. Is that it? It does make a little "different" when i start it.
    90K5
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's one of the shims. They're actually available in different thicknesses, to adjust the clearance between the flywheel ring gear and the starter gear. They mount between the starter and the engine block. Any decent shop manual should have a picture of where and how to measure the clearance.
