Help with steering arm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snidgen, May 17, 2000.
  1. snidgen
    snidgen Registered Member
    Mar 5, 2000
    47
    Im installing a four inch lift on my 72 k5 and would like to know any suggestions for removing my old steering arm. I have removed the three retaining bolts but the damn thing wont budge. The intructions say some light taps with a hammer will work it loose...NOT Any help or suggestions appreciated.
    Peace,love,and 4wd is all you need
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    put some heaton the steering arm with a torch and hit it with a good size hammer.should work.Brady
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    LIGHT TAPS!!!!! never had one come off with light taps. maybe in a perfect world. use heat if you can. there are 3 cone shaped wedges in there that have to release before it will come off. heat it and beat it!!
    your right. I don't understand the jeep thing!
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    And don't forget the BFH....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i had the same problem...get it red hot with a rosebud tip with some oxgen and acetling (i cant spell it but u can prob. figure it out) then wack the H@ll out of it..then with some pliers lift the cones out and then lift the arm off...might take awhile but i will come off.
    Chaz
    BTW....like eagle said...a BFH dose always help.
    "whoo my new pic is on the photo page...check it out!!"
  6. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    I agree, heat and hammer. I just did this on my '76 K5. I beat the crap out of it with no heat and it wouldn't move, but then I got the arm pretty hot, but not glowing red, and it came off fine. As soon as you can get the arm to start moving, beat it back down into place, and you should be able to get ahold of the cone-shaped washers and pull them off the studs. I just got the washers loose and then got them off, and then the arm just falls off.
    Be careful with the heat - I quickly wasted my upper ball joint - the grease catches on fire very easily :)
    And be careful not to screw up the threads on the studs.
    Later!
    Richard
    '76 K-5 Blazer
    '90 K-5 Blazer
