Help with surging at idle on 90 burb TBI...
Discussion in 'The Garage' started by y5mgisi, Dec 19, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I just rebuilt the motor as many of you know. Now i have a problem with surging at idle. It only does it in gear, like if you stop at a stop light it will run /idle just fine for about 30 seconds then start to do this wiered up-down surge where it tries to die then picks back up over and over but never actually dies. The truck is throughing a code 33 that i cant seam to figure out. I took the truck up to a parts store here in portland that has one of those hand held scan tools(autoxray 6000) It has a funvtion where you can whatch what all the sensors are reading but it didnt show map. So here is the stuff that i got from it; this is running at idle in park
    promID: 4551
    IAC:39steps
    temp:165.2
    open loop
    TPS: .62 volts
    Intergrater: 128
    O2:448mVolts
    Knock: 0
    Block learn: 126
    o2 cross count:174 and rising quickly.
    Does any of that strike anyone as odd? I really would like to get this surge problem out of my hair.
  2. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    In my particuler case its going to be a map problem not a MAF Someone else allready posted that link before and ive done it all with no real conclusion. The only thing i havnt been able to do is see if the map is reading .1volt or less.
  4. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    take a multimeter to the map and check it there if you cant get it on the scantool
  5. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Really? Do you hapen to know right off hand which wires i should probe?
  6. scooter122983
    Oct 4, 2006
    297
    Fond du Lac, WI
    Not off hand as im currently at work and do not have acess to my haynes book but im positive they cover it in the emissons section.
  7. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Maybe this would help?
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    With the scanner, check to see that the Park/Neutral switch is operating properly. It can cause strange idling problems if it isn't telling the ECM the correct mode.
  9. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Are you running anything aftermarket like headers or anything?
  10. dyeager535
    26,979
    I'd say signal at "B" is where you'd look for the right voltage.
    Autozone's scanner should show the MAP AND P/N switch, my Autoxray XP240 does, and it's only probably 10 years old lol. :)
