Help with tightening PS belt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 11, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I took off my AC compressor, wasn't thinking about how I could adjust the PS pump. Anybody taken off their AC and figured out a way to tighten the belt?
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I put a 4x4 block on the frame and then used a crow bat to lift (gently) on the bottom of the pump..Just becare with how much pressure you use under the block( the lines that are there....(smiley) )
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I do the exact same thing as NoSmog
    NITRO
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    you can tighten it the same way. but if your talking about how the ps pump us slightly cocked (sp), then you either have to modify bracket(s), or you can buy a plate, that bolts to the front of the head (right behind the pump), and this will fix that problem. i have one on my nova, and since i just took off my ac pump on my blazer, i will be getting one for it. if i remember correctly it was about $30-40 or so??
    fyi, if you have a stock motor it shouldn't really hurt it, but if you get into the higher rpm's or have a rather torquey motor, it is worth the investment. i had modified a bracket on my nova that still used the 1st bolt hole on the header, but that did not keep it aligned either.
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    They do make a tool for that so you don't damage the can...its made by Lisle...it hooks to the pump bracket near the frame and it has a 8 sided 1/2 hole for your breaker bar or ratchet...
    Azblazer
