Help with TPI Swap!! What's involved?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Dec 16, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    Help with TPI Swap!! What\'s involved?
    I bought a TPI unit from a friend of mine for $150. I want to replace my Throttle Body with the Tune Port System. What will I need to do this? It has the intake and computer with it.
    Will my heads work or should I get new ones for more power?
    I would like to install a cam at the same time. Any suggestions on the type?
    <font color="red"> </font color> help would be appreciated.
  2. dyeager535
    26,982
    191
    Re: Help with TPI Swap!! What\'s involved?
    Use the "search" feature on here (don't limit your search to a time frame) and spend some time over on www.thirdgen.org
    Covered extensively in both places.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">1). Yes it will work with your heads
    2). Call a few cam manufacturers and tell them what you are doing, they will help pick out the best cam for you
    What year is this setup?
