Help With Tranny!!!!!
Discussion in 'The Garage' started by BlaKK54Speed, Dec 20, 2006.
  1. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    ok, just put in new 350 long block. tranny is a 350, not sure how to connect the tranny kickback?? connects to the carb along with the throttle cable. also there is some type of hose coming up from the tranny to the carb, have no idea where it goes or what it does. comes up on the left side, carb is a brand new edelbrock 600 cfm. the truck is a 73 k10. piece of ****
  2. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    You talking about the vacume line off the tranny?
  3. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    yea where does that go? i have it plugged up right now. the tranny wont go out of first gear when its in drive. i cant do over 30 mph
  4. 90v1500
    Oct 1, 2004
    56
    Huntsville, AL
    you should have a vacume port on your manifold, it will plug into that...:D
  5. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    ok i will check it out i think i know what your talking about
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    251
    Released from Pueblo, told I belong in Southpark
    Yep vacuum line goes from the vacuum modulator on the tranny to the intake manifold vacuum port, most are behind the carb. I have seen a few that connect to a fitting off the rear lower part of the carb.
    I have a 600 edelbrock and will see if I can snap a pic of the kickdown cable for you.
  7. 70jimmy
    Mar 3, 2000
    5,962
    251
    OOPs I was wrong my tranny vacuum is hooked up to driver's side front of carb. The smaller hose at base of carb.
    These also show how the kickdown cable is connected below the throttle cable.
    Hope it helps
  8. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    yea that was it, works great now shifts fine. thanks for the help
