Help with Yoke Size
Discussion in 'The Garage' started by 1HighK5, Nov 13, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    I am about to have a new drive shaft made I have an NP205 with a Fixed yoke and a 3/4 ton 14FF what size yoke should be on the 205 and what size yoke should be on the 14FF? And is their a way to measure this to know what I got? Thank for any help
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    1310 on your t-case............1350 on your 14boltff
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    What's the 205 from? I'd guess 1310 on the 205, 1350 on the 14 bolt.
    EDIT :doah: too slow
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    if you're having a shaft made, it would probably be best to run 1350s on both ends, then use a conversion joint at the t-case or even better, change the yoke on the t-case to a 1350
  5. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    a 1350 CV w/flange at the Tcase & 1410 with yoke at the axle, thick tubing, w/ CK5 discount & shipping will run you about $550 from HAD. :D
  6. 1HighK5
    Feb 7, 2005
    140
    New York
    Thanks I want 1350 joints at both ends of the drive shaft but I don't think I need a 1350 CV I wanted to know because I am going to order a 1350 U bolt yoke from North West Fab works for the 205. Also to answer another question the 205 is a 1970 Fixed yoke.
