Help with Zero-Rate install?
Discussion in 'The Garage' started by eldon519, Jul 2, 2003.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Can someone give me some advice on how to drill out my U-bolt plates to move the axle forward 1.5". I'm drilling with oil and low RPM with slight pressure but I'm making really, really slow progress. Can anyone recommend a quicker way to do it? Also, how small of a bit should I start with? I have an angle grinder which could make the job go alot faster but I'm afraid to cut that big of a groove into the plate for fear of compromising it's strength. Any advice helps. Thanks guys
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Sharpen your drill bit /forums/images/graemlins/thumb.gif
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    drill press /forums/images/graemlins/thumb.gif
  4. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    I don't have a drill press and the bit is brand new.
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well if you didn't use oil, its probably dull now.
  6. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    I used oil. I'm just wondering if it would work better if I applied more pressure or if I ran it at a faster RPM. I've always heard it was best to drill metal slowly but I could be wrong.
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Just chuck it in the drill, pull full throttle and put all your weight on it, should work rather well /forums/images/graemlins/grin.gif Your bit probably won't last long but it will drill 2 holes /forums/images/graemlins/thumb.gif It's the way I always work except when using the mill but I just resharpin my bits on the bench grinder everynow and then, all the bits I buy are dull and need to be sharpened, 3 bucks a pound /forums/images/graemlins/grin.gif
  8. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gifSo in other words just give it Hell...I'll see what I can do /forums/images/graemlins/thinking.gif
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Make sure your going the right way with the drill too. /forums/images/graemlins/thumb.gif
    Just throwing it out there!
  10. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i just finished putting mine on and you really need to find a drill press, i had mine done in about 10 minutes at the base metal shop, a machine shop could probablly do it to for a few bucks, just get the piolt hole done in the correct place /forums/images/graemlins/thumb.gif
