Help! Wont start!
Discussion in 'The Garage' started by 89Silverado, Feb 12, 2005.
  1. 89Silverado
    89Silverado Registered Member
    Dec 14, 2004
    6
    Connecticut
    I went to start my 89 Blazer tonight after I just drove it less than two hours before. I have never had any trouble with it untill now. After cranking it forever I went and smelled the exhaust. I didnt smell any gas at all. Also, I usually hear the fuel pump when I first turn on the key, and im not hearing it at all now. It does have an aftermarket starter/keyless entry installed, could my problem be there? I'm new to EFI, ive always owned and worked on carbed vehicles(no probes either) so Im not sure where to start, fuses, wiring, etc.
    Thanks!
    Tony
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    how many miles on it? and do you here the pump run? if no pump check pump voltage with key on and se what you get. and you need 2 people to test. the key off for about 10 sec then be ready and turn on it will cycle for about3-4 sec then off. and crank will be on all time. if no volts and over 80-90k then pump bad thats life span on average pump.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    If that doesn't work check the fuel filter.
  4. 89Silverado
    Dec 14, 2004
    6
    Connecticut
    I do not hear the pump run at all. The truck has 131K miles on it.
    Thanks!
    Tony
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    i work at shop. and if i wason this one i would do pump. sounds like all others i have done. p.s. you might need the gm tag id off sender before changing it. and if in rust belt expect lots of rust up there . and do a filter also.
