Help - Won't Start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Apr 23, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    Help - Won\'t Start
    My blazer won't start this morning, It's turning over, but doesn't sound as if it's firing. I drove all weekend, parked it last night and it was running sweet, this morning however it just will not start.
    I went over an incredibly bumpy road last night, shook the whole truck to hell, could this have done something to affect it not starting today, I noticed a metal braided (Looks like ground strap) attached to the rear of a rocker cover, this strap is still attached to the rocker cvr but is just hanging there, any ideas anyone, please tell me its a fuse or something....
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Help - Won\'t Start
    Check all your fuses first, then see if you can reattach that ground.. The ground may possible be your problem.
    Also check to make sure all your plug wires and coil wire are still connected.
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Famous previous owner of mine left that ground wire unhooked for me, along with the choke. It will run with out but its a good safety deal to have hooked up. I'd pull one of your plugs with the wire still on and rest the metal end of it on the manifold. Make sure NOT to touch it after that. Then get a buddy in the cab and crank it a little. Check to see if its firing. If not then something probably came loose in your distrubutor.
  4. bking
    Jan 4, 2001
    176
    Thanks guys, well, I checked what I thought was the obvious things first, all fuses, and all wiring, below the dash and under the hood, the truck was turning over but not firing. I was on my own so I couldn't crank the motor and check for a spark.
    So, About now I was getting severely pissed. I jacked up the front end and crawled below for a look, and there it was, I almost missed it. There was an orange heavy wire, with a male flat connector on it hanging loose, the female end was nearby, so, I stuck them together, and, well, it started. Obviously the shaking the truck got the night before had loosened this connection, bummer thing is, it took me 5 hours to find it.!
  5. bking
    Jan 4, 2001
    176
