Help!
Discussion in 'The Garage' started by K5chick, Jan 28, 2005.
  1. K5chick
    K5chick Newbie
    Jan 28, 2005
    FL
    I'm not that knowledgeable on cars in general, and I just bought a 1986 K5 Blazer. it's an ex-military truck...it's diesel/ runs off of 2 batteries...but the only way it will start is to jump it every time so something is wrong with the alternator or something...the batteries are good...and it runs great when it gets cranked...could somebody please tell me what to do...i want to start working on it myself, but i need to know how to fix it...i cant find any other info on working on this truck...PLEASE HELP!!
    :k5:
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Does it do this in the morning. Or if you shut the truck off and went to turn it right back on the batteries would be dead?
  3. K5chick
    K5chick Newbie
    Jan 28, 2005
    FL
    if i shut it off, it WILL not crank back up...unless jumped off...again
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    First off check your + wire running to the starter. On my K5 the + wire was hitting my fan belt and made a bare spot that killed my battey fast. Or it could be your alternator. Have your alternator checked.
    Adam
  5. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Sounds to me like bad contact at the batteries if the batteries are good. Start with checking the batt posts, make sure theyre clean and the terminals are tight.. Check the voltage coming from the Alt.
  6. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    you may want to do some research. alot of military trucks are 24 volt.
