  1. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    Just got a 454 out of an 82 c-30 crew cab. Had it running before we pulled it and it needs freshened up. I've been researching parts and different combos. This is the first BBC I've attempted to tear into. All my rebuild experience is with small blocks. I'm confused :confused: about cylinder heads, can some one please explain; open chamber, closed chamber, oval port, rectangular port and peanut port. It seems from what I've been reading for low end torque, the peanuts are the way to go. Thanks for any help
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Ok, I am by no means a BBC expext. That said, all those terms are not describing the same thing. Open chamber and closed chamber refer to the design of the combusion chamber. Oval port and rectangular port refers to the shape of the exaust port where it meets the manifold/header.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    open chamber =Low compression
    Closed chamber= High compression performance head
    Peanut port= Usually used on trucks Describes small oval almost round intake ports. Good low end up to 4500 rpm. Open chamber
    Oval port= larger oval intake ports Good for performance came in both open and closed chamber.
    retangular intake port= High performance head. used in high performance engines like 454 501 HO Can be either open or closed chamber.
    On BBC you cant swap intake manifolds around. Intakes are made for their specific head design If you have a peanut port manifold it can only be used on a peanut port. same for Oval and rect manifolds.
  4. mojo-jojo
    Sep 26, 2003
    101
    PGH PA
    Thanks for the info, things are starting to make sense.
