help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txhotrod, Apr 6, 2005.
  1. txhotrod
    txhotrod Registered Member
    Jan 31, 2005
    33
    Texas City, TX
    Ok after goin through 10 diffrent set of inner seals for my d44 front end on my blazer i decied to scratch off the pretty paint and see if i could find the bom #'s. Well I found them but like everything else with this particular axle it comes up unlisted. The bom#'s are 603675 then a space and a 2 to the right of these are the #'s are the #'s 3267A E or F. I belive the second set is the date.. Is my axle realy from 1967!!!
    This is my dd and was bought with a lift already on it as well as a body swap. I dont belive a word of what the guy said when i bought it he said there was match 3.73's but actually they were 2.78's and 3.08's. A month ago i replace every seal that was in the axle and upgraded to 4.56's, but these weren't replaced because they weren't in the axle to begin with. Well after the break in period I went wheelin and noticed that the oil was leakin from the tubes. I tore apart the axle and found out the seals weren't even there...If any can help me with this i would greatly apperciate it I need my truck back his is my DD.
    Thanx ,
    Blazerkid
    This is for my son who couldn't log on
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    603675-2 is a 3.07 ratio Dana 44 front axle out of a 1976 half ton GM truck.
    603675
    DANA 44 FRONT
    Year 1976
    Make CHEVY
    Model K5 Blazer, K10 1/2 Ton Pickup & Suburban & Panel Truck
    Number of axle splines: 30 FULL
    (STANDARD-pinion) FRONT
    Number of cover bolts: 10
    Diameter of ring gear: 8.5"
    Number of ring gear bolts: 10
    Pinion Shaft Diameter: 1.375"
    Pinion Splines : 26
    Low Case Ratio : 3.92
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Tim,
    Where did you find the info on the breakdown of the differential number? Just wondering where to go in the future.
  4. Blazer1970
    1,600
    Old Mission, MI
  5. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Thanks! That's another handy link for the list. :grin:
