Help!
Discussion in 'The Garage' started by TEAMROPER, Apr 18, 2005.
  1. TEAMROPER
    TEAMROPER Registered Member
    Aug 8, 2002
    29
    San Diego
    I have a 86 Blazer with a mild built 350. Does anyone know where the vacuum line goes to off the distributor?? Does it go to the carb? Thanks for any info.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes, should go to one of the side or front ports on the carb.
  3. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    Thanks, Mike
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Anytime. It's been a while, but I think I always had mine on the passenger side of the carb towards the front on a Q-jet. :)
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Put your finger over the port on the carb. while at idle, if vac. is present find another port. You want vac. off idle not at idle (ported supply)
  6. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    cool thanks guys. I will give it a try.
  7. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    Any susgestions would be a great help. Who makes the softest riding leaf springs for a 86 chevy blazer around a 6" lift 36" tires 350 motor??
  8. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Don't know about the 6", but I had Rough Country 4" on mine for a long time with 38s and they rode very well.
    I seem to remember them being reasonably priced as well, but that was several years ago...
    Good Luck
