Help!
Discussion in 'The Garage' started by Cove-Rider, Dec 20, 2005.
  1. Cove-Rider
    Cove-Rider Registered Member
    Dec 13, 2005
    25
    Mountlake Terrace, WA
    My 1985 CK10 Blazer wont pass the washington state emmsions test. it is carborated and has 3 inch flowmaster on it with the stock 305 motor. does anybody here have any tips on how to get it to pass?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Shoot it and put it out of its misery!!! :haha:
    What isnt it passing? Co? Co2? Hydra carbons? Does it have a cat? When was the last time you tuned it or rebuilt or adjusted the carb? I ended up having to replace my carb the first time I smogged my 86 K5.
    Oh yeah... Welcome to the forum!!
  3. Jimmydriver
    Jimmydriver Registered Member
    Nov 30, 2005
    8
    Reno, NV
    Make sure it’s tuned up, good plugs, wires, ignition system up to snuff.
    Pollutants build up in oil so a fresh oil change and new filter.
    Make sure the engine is hot, at least 20 minutes on the freeway getting there.
    Retarding timing will bring down HC but cause a slight rise in CO. Usually running at about 5 degree advanced and run the idle speed right below the high test limit (1250 RPM where I live) should get it to pass assuming no major things like carb. rebuild are required. Remember to adjust the carb. before running idle speed up, vacuum tune works well.
    The trick most everyone uses is alcohol. Isopropyl alcohol used for water in gas works good, sold as “dry gas”. Let the tank get down just below a 1/4 tank then add a pint of alcohol (Isopropyl alcohol from the grocery store works too).
    If it doesn’t have cats you can always get 2 old ones from the bone yard and slap them on before you take your rig in. What you do with them after the test is up to you.
  4. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    put on a new cat converter not used new ones will burn up all the bad stuff
  5. Cove-Rider
    Dec 13, 2005
    25
    haha not gonna shoot it i just bought it! it isnt passing because it has like 6 times the aloud amount of hydro carbons is what a shop told me who ran a test for me. they played with the carb a bit and said it was running a bit lean but coul be fixed. its got a quadra jet carb in it right now it use to have a holley. right now though the engine use to have an air pump on it but doesnt anymore so that could be part of it but i dont know where to get one cheap? it has a small after market cat because of the flowmaster but i dont know how much the would affect things. well there is some more info if it is helpful in dignoseing how to fix my beast.:o
