Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5guy, Mar 6, 2006.
  1. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Just put a brand new set of superlift springs on the rear of my K5.I noticed that the driver's side sits a bit lower than the passenger's side.I found a good flat parking lot to park and took some measurements.The driver's side does sit an inch lower than the passenger's side:eek1: .What do I do now?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Loosen the spring eye bolts a bit, drive it around the block, the tighten them back up. If they were tightened while the truck was still jacked up, they can bind and cause wierd stuff to happen.
  3. 89K5guy
    Jul 11, 2005
    174
    Ohio
    Thanks for the tip:bow: ,I will try this first thing tomorrow.The springs were tightened with the truck on a lift.If by chance this doesn't fix it,what do you suggest next?
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Call Superlift. :D
