HELP!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84BLAZER7, Jul 3, 2001.
  1. 84BLAZER7
    84BLAZER7 Newbie
    Jul 2, 2001
    Iowa
    I NEED YOUR HELP. i HAVE AN 84 BLAZER AND THE INSTRUMENT LIGHTS DO NOT WORK. WHEN I TURN ON THE TRUCK THE FUSE AUTOMATICALLY BLOWS. ALSO THE SEAT BELT WARN. BUZZER DOES NOT WORK.THE BRAKE AND CHOKE AND DOME LIGHTS ALL WORK. I THINK THE EXTRA ENERGY THAT IS SUPPOSED TO GO TO THE BUZZER GOES TO THE INSTRUMENT LIGHTS THUS BLOWING THE FUSE. ANY SUGGESTION OR THOUGHTS YOU HAVE ARE MORE THAN WELCOME. HELP ME. (BY THE WAY IS THE BUZZER A SMALL YELLW PLASTIC THING WITH 3 WIRES COMING FROM EITHER END, I DON'T KNOW BECAUSE IT HAS NEVER WORKED)
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I don't have a answer to your question, but for future reference don't type in ALL CAPS! It's harder to read and it means that your yelling.......and fill out your profile........
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*
  3. Grim-Reaper
    7,385
    Atlanta
    Did you just install a stereo? People screw up all the time and try to use the factory light wire as a ground wire. Check that first, thats the usual place that you see these sorts of problems.
    Yeah dude caps is rude in a forum.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  4. Storm Trooper
    Nov 24, 2000
    4,640
    If you don't have a meter to go through and check out each component then I sugest that you try to figure out what items are on that fuse that don't work. Disconect each one, mark them so you don't forget which wires go where then put a new fuse in. If it blows, you didn't find all the items powered on that cucuit, keep checking. If the fuse does not blow then reconnect one item at a time until you find the one that blows the fuse and replace it. If the seat belt buzzer is on that cucuit, lift the carpet and look at the wires there. It's a good place to cause the wires to get a hole rubbed through and cause a short. good luck.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  5. Grim-Reaper
    7,385
    Atlanta
    Cut him some slack...he's new he didn't know.
    Grim-Reaper
  6. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I had that happen to me when I was rewiring my stereo... I had a wire grounding that shouldn't have been. Check around really well for wires that lead nowhere... if you find some, then find where they are attached and fix them so they ground the right way, or remove them if they are not needed.... [​IMG]
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  7. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i had this happen to me but i don't have a seatbelt buzzer. mine was a short in my light switch. on the dimmer controll had melted and shorted out some how. just go throw all the wires on that fuse and find out witch one is shorting out.
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You've obviously got a wire shorting directly if you're popping a fuse that quick. I'd check the stereo wire too.
    I didn't ground it the 1st time I put in my stereo...I hooked it up with the ignition (orange or yellow, can't remember) wire thinking that's what it was....so when I turned the key on, the parking lights came on! Took me a few months and another stereo install to realize what I'd done!
    Tim
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Sorry, didn't mean to sound too harsh [​IMG]
  10. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> recent stereo work = blown fuses .......look there first with a check light .
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
