Help!!!
Discussion in 'The Garage' started by olskool, May 1, 2006.
  1. olskool
    olskool 1/2 ton status
    Oct 19, 2005
    138
    the frozen tundra
    So today I picked my son up from school, swung by Napa to get a couple bolts. Driving up to a stop light in third gear about 30mph I let off of the gas and the compression braking kicked in (it is a '77 k5, 350ci with a sm465/205) the truck died. So there I am stuck in the right lane of the road. I then pushed the k5 over to access the situation. After numerous attempts of starting it, it would not fire. I called a buddy and he towed me home. The first thing I did was pulled the plugs to see if they were fouled and they all looked fine. I then checked for spark, nothing, no spark. All my fuses are good. The battery wire going into the coil has power going to through it as well as the tach terminal. What is the proper way to test a coil? Is there anyway that with the compression braking the timing chain would have skipped a tooth or two? The rotor still turns.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    could put #1 up on tdc and see if the rotor is pointing in the direction of the #1 terminal on the cap.
  3. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    if no spark it isprobly the modue in the distributor under the rotor.
  4. olskool
    Oct 19, 2005
    138
    the frozen tundra
    How do I check the module in the distributor?
  5. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    Any of the autostores have testers that can test the module real quick, after you have it out of the truck, if you can find anyone competent to run them.
  6. olskool
    Oct 19, 2005
    138
    the frozen tundra
    Update
    My distributor is only 2 months old, I thought there is no way it could be the ignition module but I changed it out this morning and it fired right up. Thanks for the help.
  7. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Reman ? A1- Cardone maybe ? some are better then others.:( :laugh:
