Help!!
Discussion in 'The Garage' started by tenderfoot1877, Sep 13, 2006.
  1. tenderfoot1877
    tenderfoot1877 Registered Member
    Apr 10, 2005
    13
    San Antonio
    I have an 88 blazer, and for some reason I am not getting ignition in the #4 and #6 cylinders. I have changed out the cap and rotor, changed the spark plugs, changed the plug wires, and I am getting spark all the way to the plug but when the truck is running and i pull the #4 or #6 wire from the cap, it doesn't effect the engine. Somehow, fuel is not getting to those two cylinders. What might be the problem?
    HELP!!
    __________________
    6" rough country lift
    35/12.50/r15
    15" MT's
    4:56's baby [​IMG]
  2. el diablo
    el diablo Registered Member
    Jun 12, 2004
    30
    Mt. Home Idaho
    Do a compression check. If you have two dead cylinders side by side, usually its a blown headgasket.
  3. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    I have about 100psi in both cyllinders.
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    how does that compare to rest of the cylinders? They should all be around 10-15% of each other.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    1-8-4-3-6-5-7-2:bow:
  6. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    :doah: Ive done that a few times.
