help!!!!
Discussion in '1982-Present GM Diesel' started by MUDNUTT, Feb 18, 2002.
  1. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    need some help! was driving my 94 k3500 dually with the 6.5t when the alternator went out, threw the belt and overheated the truck. i replaced the alt. and belt, then filled it back up with antifreeze and started it. when it fired i could not see behind the truck thru the clouds of white smoke and it idled like a gas motor with a big cam. i think i blew 1 or both of the head gaskets but im not sure because the exhaust didnt smell like coolant. anyone have any ideas???
    <font color=red>DRIVE IT LIKE YOU STOLE IT[​IMG]
    <a target="_blank" href=http://community.webshots.com/album/24975635VazeJOnxiI>SEE MY PHOTOS</a>
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Check fhe oil for coolant, check your coolant level, check for bubbles in coolant while engine is running.
    White smoke doesn't sound good, though.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  3. MUDNUTT
    Aug 1, 2001
    339
    Mn
    checked the oil, dosent seem to be any coolant in it. coolant level seems okay but its hard to see if theres any bubbles in the coolant while running because the radiator has no opening. the cap is on the expansion tank.
