HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SNOHEAD, Jul 15, 2000.
  1. SNOHEAD
    SNOHEAD Registered Member
    May 8, 2000
    12
    MT,WEST YELLOWSTONE , GALLITAN
    FOR STARTERS I AM PLANING ON BRING MY BLAZER ACROSS COUNTRY FROM MONTANA TO NEW JERSEY . IN ANY CASE I AM WONDERING IS THERE IS ANYTHING I SHOULD BE CARFULE OF ON THE TRUCK ITS ALL STOCK AND I JUST REPLACED THE U JOINTS . I PULLED THE FRONT DRIVELINE AND IT SEEMS TO HAVE MORE PICKUP AND GO. IS IT SAFE TO LEAVE THE DRIVLINE OFF OR WILL IT CAUSE AND IMBALANCE IN THE LONG RUN?
    THANKS IN ADVANCE
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    I think it is totally safe. I believe I read on this forum and 4x4 magazines that you can remove the front drivshaft and there wont be any damage in the long run. But I am not 100% sure.
    <font color=red>Chevy4x4<font color=red>[​IMG]
    http://fourbyfour.coloradok5.com
  3. getsome
    getsome 1/2 ton status
    107
    Colorado
    I pulled off my driveshafts all the time with no problems. Mostly I do this to have new ujoints put in. I just pull the front driveshaft off and drive it down to the shop then they replace them then I take it home put the front back on then take the rear on off and put it in 4hi and do the same thing. Your not going to hurt anything by taking it off.
    Getsome
  4. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Just make sure you take your front driveline with you. That way if something happens to the rearend you can just pop the driveline back in, kick it into 4wheel drive, and run on the front tires. It's saved my butt a time or two.
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
