Help!!
Discussion in 'The Garage' started by MR.4x4, Jul 31, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i have a Blazer 75 (k5), with 35 tires, and my rear tire is touching my rear fender when it Flex(only in off-road), what can i do??
    Body lift??
    Thanks for your help!!
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Have you got a lift? Did it just start doing it recently? Or do you just need justification buying a bigger lift? /forums/images/icons/grin.gif
  3. MR.4x4
    Jul 17, 2002
    66
    Hi, i have that Blazer with SOA Spring Over Axle and for 1 years, but i had never offroad with it, and all the paint was off because of the tire.
    I need more lift, or how can i ``control´´ the Articulation??
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    First I will say to fill out your profile. Second I will say break out the sawzall and cut the fenders till the tires fit /forums/images/icons/wink.gif . How much lift is on your truck now? Limiting your articulation is possible with extended bumpstops and limiting straps, but that isn't the best thing for offroad. If it isn't a problem on road and you don't go 'wheelin much, I would say to leave it alone. We need some more info on your setup /forums/images/icons/tongue.gif .
  5. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    BTW all fullsize blazers are spring over axle /forums/images/icons/wink.gif
  6. MR.4x4
    Jul 17, 2002
    66
    With a body lift in the rear this problem should be eliminated?? /forums/images/icons/laugh.gif
    PD. I thaught it was lifted because the SOA je je /forums/images/icons/smirk.gif
