HELP........
Discussion in 'The Garage' started by Bearz, Jan 16, 2003.
  1. Bearz
    Bearz Newbie
    Nov 1, 2002
    4
    Red Deer, Alberta, Canada
    I need some help, I just bought my first blazer a 1991 and it's great, I put a 6inch lift and 35's on it but I have noticed a few problems. The lift is 6" springs up front and blocks in the rear(also put brand new leafs), but now I notice it sits about 2" higher in the front /forums/images/graemlins/crazy.gif it also drives like a lumber wagon... I tried taking out one spring from the front packs and also took off the sway bar but to no evail /forums/images/graemlins/confused.gif it still sits higher in the front and still drives like a 5-ton??? can anyone help me get a better ride and ride hieght???
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    When you put the lift on, How tight did you tighten the bolts on the springs and shackles? Spec is like 52 foot pounds. Cranking on these can cause a rough ride. What kind of lift did you get?
  3. Bearz
    Bearz Newbie
    Nov 1, 2002
    4
    It's a pro-comp lift, we thought we were overtightening so I got some new front shackles made by my bud that dont crimp on the bolt and allows for smooth movement...still rides bad /forums/images/graemlins/confused.gif
