HELP!
Discussion in 'The Garage' started by aj_johnson, Jul 24, 2003.
  1. aj_johnson
    aj_johnson Registered Member
    Jul 20, 2003
    40
    hey guys, I need some help here..
    I got a '73 blazer with no key!!
    1. how do I get the ignition switch out???
    2. how do I hotwire it?
    THANKS!!
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I know on my 84 you have to pull the steering wheel off and then pull the column apart. Sorry about the year difference. /forums/images/graemlins/tongue.gif Good luck!
    Kris
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I think the ignition switch requires you to remove the steering wheel and some other parts.
    I ain't gonna go anywhere near the hotwiring part.
    You could just have another key made for it or have a new one installed. Alot easier and it also doesn't look like you are trying to rip Blazers off!! /forums/images/graemlins/ignore.gif
  4. aj_johnson
    Jul 20, 2003
    40
    lol... I mean for only a temporary solution untill I can either get another key made, or a new switch... but that won't be till next week! anyhoo.. I know I need to pull it apart, I got the wheel off now, and the steering wheel lock off, the turn signal assembly sort of out, but I can't figure out how to disconnect it so I can pull the rest of the collumn out!
  5. aj_johnson
    Jul 20, 2003
    40
  6. aj_johnson
    Jul 20, 2003
    40
  7. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    You have the steering wheel off, good
    If you are all the way down to the turn signal you are doing pretty good.
    You have to slip it to the left side. The plug is under the dash and a real b /forums/images/graemlins/blush.giftch to get out. Don't worry about it.
    Next to the steering spline shaft is a small slot shaped hole. Use a thin flat piece of metal to push in there and release the key cylinder. You need to work it around a little bit. It should eventually pop out a little bit.
    Gently work the cylinder out and press in the new one.
    Reassemble steering column. DO NOT overtighten the screws, they are in soft aluminum (the downfall of all Chevy's between 73 and 92). Make sure you get the spring on the spline shaft all the way on, otherwise nothing will go on right and your horn will blast during the operation /forums/images/graemlins/crazy.gif.
    Good luck
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sence no one will tell ya how to hot wire, I will. Like the name says, just run a wire from the positive side of the batt. to the positive side of the coil, and jump the starter at the silanoid. But if you can't steer it, that doesn't do you any good. /forums/images/graemlins/smirk.gif
  9. Grim-Reaper
    7,385
    Atlanta
    Lock Smiths usualy charge about $65 to do the job. My buddy ( A locksmith) is about to swap mine out this weekend because the outer knob part is fubar.
