  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I need a 10bolt axle shaft for my rear(30 spine). My left rear tire was covered in oil so I was going to replace the bearings and seals. The shaft is worn from the bearing going bad. Does some one have one I can borrow til May/June or one I can buy, please let me know. We are going to Big Bear on Saturday.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Some one has got to have this. Please help!!!!
    Not FROM the people
  3. northgate
    northgate Registered Member
    Sep 29, 2000
    75
    Sisters, Oregon
    Try an axle saver bearing. They move the bearing about a half inch further down the axle allowing you to re-use the axle. They are available at most good parts stores (NAPA, etc.)
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I'll check that out. Thanks. But the bearing is in all the way now. Is it special design bearing?
    Not FROM the people
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Last March my seal crapped out on me. The guy at the parts counter didnt have an axle available but he said to let the new seal hang out a little or push it in a little further "just for now". Well its been..... what, 9 months and its still holding. I'm getting a little nervous about it though. Just a thought!
    creepin' and crawlin'
    Jim
  6. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I changed the seals and bearings(and soaked breaks) today. All I need is a shaft and I'm back in business. The axle is worn down where the bearing rides on it. So it's too lose on the bearing.
    Not FROM the people
  7. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    the saver bearing has the seal included and moves the location on the axle where it rides their 25$ I think and kragen has em theyre timkin made in usa.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  8. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    A reat thanks to all of you for your help. I found one at the trans shhop that did my 700r4 and 14bff. http://www.blazen91.coloradok5.com
    Not FROM the people
