helppppp with my first tbi carb
Discussion in 'The Garage' started by johnathon1968, Feb 2, 2006.
  1. johnathon1968
    johnathon1968 Registered Member
    Feb 2, 2006
    5
    oregon
    hello im new here. i just got a 1988 chevy van. with 305 engine and tbi carb.im trying to find out how to adjust the idle on it. thanks for any help.
    johnathon1968@yahoo.com
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Well the TBI really isnt a carb, its closer to fuel injection and if your idle is off there might be something else wrong, I am sure someone else with better knowledge than me will help. Also if you explain whats wrong with the idle it will help others to answer your question.
  3. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    the computer controls the idle there is a manual way to adjust the throttle stop but it will usually only work to adjust the idle up, because if you adjust it down past what its at the computer will just hold the idle up
  4. johnathon1968
    Feb 2, 2006
    5
    oregon
    thanks for your reply. the problem is the idle seems to be very high. the engine is running fast at idle. and 1 ore thing the oil light stays on at idle.but when you push on the gas it goes out.
  5. BoDapper
    BoDapper Registered Member
    Aug 22, 2005
    19
    Libby,MT
  6. johnathon1968
    Feb 2, 2006
    5
    oregon
    What All Would I Have To Do To Put A Carb On Here..
  7. pumpkin
    pumpkin Registered Member
    Nov 5, 2004
    14
    If it is idleing too fast, then it is most likely a vacume leak. Quite common for the throttle body base gasket to leak.
  8. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    If you put a carb on it then it wont be smog legal anymore.
  9. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    Why would u want to revert to a carb?
  10. johnathon1968
    Feb 2, 2006
    5
    oregon
    ok i got the idle working right.. it was a vacume leak. now i have a new problen. i cant get any oil pressure . i put a new oil guage but still no pressure. what do you think is going on.
  11. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    well i would not run the motor with no pressure is what i would suggest
  12. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Are you positive the replacement gauge is good? Are you positive that your sending unit is OK? How about the connection between the two?
    This is slightly different, but gauge-related: Wwhen I bought my K5, the coolant temp gauge didn't work. It wasn't the sending unit at fault, nor was it the gauge, but rather a wiring problem. When a PO had done a "home rebuild" job on the 700R4 and had bolted it back up to the engine, they had tightened down a bellhousing bolt head with the coolant temp wire underneath! Apparently, no one thought that a dead coolant temp gauge was worth debugging, but it's been fixed now by replacing the wire.
