Helpppppp!!!!!!
Discussion in 'Rocky Mountain Region' started by 3 on the tree, Jun 5, 2006.
  1. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Hey all, the burro broke tonight. If I don't get a part, and quick, will not make the dunes this weekend. On the 250 6 cylinder, there is a housing that bolts to the front of the head and turns up. The t stat sits on top of it, and then the water neck. Well, my housing broke tonight, putting in a new temp sending unit. It leaks pretty profusely now. I have been on the net for over 2 hours trying to find one, with no success. Any help would be greatly appreciated!!!!
  2. fred2mihi
    fred2mihi 1/2 ton status GMOTM Winner
    Nov 26, 2004
    1,272
    Way West in Co.
    Mike I know the problem, the burro is fighting back for making her run around topless. :):)
    How about the guy east of town on the north side of the highway? He has 6 or 8 different GM trucks setting there rusting away, he might have a 6 banger in one of them. Also at Cimmarron there is that old garage with trucks of varing degrees that might be a place to check. Hope you get the problem fixed quickly.
    fred2mihi
  3. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I'll try to get by the u-pull-it today and see what I can find.
  4. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    I will make a couple calls today and see if I have any luck. I will let you know. Gotta hit some parts stores and a buddy with a stash of gm parts anyway.
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Hey Scott, look back on the North side, there was a 6 popper truck unless they crushed it.
    Any way you can weld your old one temporarily or is it stripped at the temp sender?
  6. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Can't weld it. The crack is from the threads inward. Being cracked, the housing will not grip the sending unit tight enough to seal, even with teflon tape. I am starting to believe that there are some drawbacks to having a "unique" drivetrain. If it keeps breaking hard to find parts, that 429 could find itself being crossbred.:eek1: :eek1:
  7. 70jimmy
    Mar 3, 2000
    5,953
    248
    Not sure if this will help you any but supposedly GM part # is 3052705. You might try you chevy dealer.
  8. 70jimmy
    Mar 3, 2000
    5,953
    248
    I am going to look at a couple engines at a buddy's house after lunch. If they have it I will pull it and let you know.
  9. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    There were several appiclable trucks, but they are gone now. Only one 1st gen style pickup with no motor. Looked through a couple of newer 73-78 pickups too. No luck.
    The did have a 89-90 burb - no motor of course - and a 90 2wd 1-ton crew cab - motor missing everything but the block.
  10. 70jimmy
    Mar 3, 2000
    5,953
    248
    Just talked to Mike a few minutes ago. He ordered a new one from the dealer and will have it tomorrow. I found a backup used one for him also in case the dealer falls through.
  11. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    A Big Thank You
    This goes out to all who aided me in my search for a lower thermostat housing. You guys rock the house!!!!!! Nowhere else would a group of people expend so much time for no money.:bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
  12. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I thought I was getting paid?? :haha:
  13. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    You are absolutely correct. I owe you 1 wet willie!!!!!!!:haha:
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I think I'd settle for a bowl of dirt. I've seen enough water in the last 4 weeks to last me a lifetime.
  15. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    Just as a fall back for 6 cyl parts, have you ever heard of Clifford Performance? their teck line is (951)471-1161 or their web address is http://www.cliffordperformance.net they do nothing but hipo 6 cylinders, Chevy/GM, Ford, Mopar, Jeep and even HUDSON ! ! ! They do cams, intakes, exhusts, Fuel Injection set ups, Lots of hipo stuff for those long ass engines! Want a triple weber side draft fuel injection system? They got em! ! ! ! ! :haha:
