herculiner dash,door panels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by joker89blazer, May 31, 2002.
  1. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    what about repairing the gm dash that explodes into cracks from sunlight with a vinly dash repair kit and covering it with herculiner ? would herculiner stick to plastic ok ? work ok on door panels ?
  2. buick528
    buick528 Registered Member
    May 3, 2002
    55
    montgomery,il
    I started doing this on mine.looks good,but if the dash is already cracked it doesn't fill in holes very good.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I think its too rough to be that close to your arms. If you were bouncing around and scraped your arm down the door panel you could loose a couple pounds of flesh...
  4. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I made the (mistake ?) of putting herculiner on my door at the very top past the panel (on a 1dst gen) and found it made me a better driver! I keep both hands on the wheel now....elbows up to to keep em away from the 40 grit feel of the upper door panels.
    Seriously, I havent found it to be much of a problem but in retrospect, rattle can would have been better.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Herculiner also fades in the sunlight and like the others have said it is somr rough stuff. I did the cargo area in mine and trying to crawl in the back with shorts on is murder on the knee caps.
  6. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i did my my whole blazer in herculiner inside and out.the dash might be ok but i strongly urge you not to do the door panels(that is if you like having skin on your arms).this sh!t is coarse.when i'm wheelin i like to rest my arm on the door,if you hit a few good bumps look out.i've got many of raspberrys this way.also it does fade quite a bit looks kinda like a charcol color after a while.but its tough as hell.here's my webshots page if you want to check it out.
    http://community.webshots.com/user/efilnikufecin
