herculiner or??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76JIMMYWPG, May 6, 2002.
  1. 76JIMMYWPG
    76JIMMYWPG Registered Member
    Apr 28, 2002
    19
    Winnipeg, Manitoba, Canada
    I have a 76 jimmy in great shape outside, but in need of tlc inside, the carpet is so weak if you turn you foot while planted it tears, I am interested in putting a liner on the floor, but not sure which one to use. I am in Canada so if there are any suppliers of the material known of up here, their whereabouts would be a big help.
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    You can always get vinyl or a rubber substance, they work great. I run vynl carpet or whatever and it makes cleaning MUCH easier.
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i dig my herculiner. see pics in my webshots albums. If you had any specific questions about it, lemme know,
    J
  4. 76JIMMYWPG
    Apr 28, 2002
    19
    do you have pics of what your floor looks like? i'd like to see. I am really leaning towards doing the herculiner myself, but would like to hear some more opinions!
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah... on my webshots albums... link is in my sig...
    J
  6. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    I have used the herculiner on J**ps its easy to do and holds up well. I will be using it on my sub. when I put the interer back together.
  7. sagechicken
    sagechicken Registered Member
    Feb 19, 2002
    71
    Wyoming
    I put the herculiner in my company truck. If put in right, I'm sure it will hold up pretty good. I used the scouring pad that was included with the kit, but I wish I would I would have used a fine sandpaper to rough the bed up. It has scraped off in a couple spots, but I also abuse the bed on a daily basis.
  8. 76JIMMYWPG
    Apr 28, 2002
    19
    Thanks for all the input, I am going to go with the herculiner floor, seems its too expensive to get line-x or other spray in liners, and they didn't seem to keen on doing it either. Now all i have to do is find a place in central Canada that can supply me with Herc!
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    1 more thing... if you want the herc to maintain the shiny look it has when you install it, you MUST spray some kind of UV protecting top coat on it... otherwise after a few days of sun it will turn a VERY flat black. Personally, I dont care... so I have never worried about it... but others might want a specific look...
    J
  10. 76JIMMYWPG
    Apr 28, 2002
    19
    Thanks again Jekbrown. Do you mean like a clearcoat?Or does Herc have a uv topcoat for it? Now all I have to do is find someone who sells Herc in Manitoba, Canada, or anywhere in Canada for that matter!
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you can order it online.
    make sure to either grind the surface or POR-15 it to keep the rust from spreading.
    I am putting herculiner down than a vynal mat to keep road noice, creaking and heat/cold out. once I do that, i will be able to clean the truck with a hose (inside and out) and not worry about rust.
    Pics can be seen in the sig.
    JMHO
  12. 76JIMMYWPG
    Apr 28, 2002
    19
    When you say to grind the surface, do you mean grind all the paint off the bed? or just scuff it up with some sandpaper? and then clean it with a mineral spirit or something? What is POR-15?
  13. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I'd say a wire wheel would suffice...unless there is a lot of rust scale then it would be better to grind that off first.
    POR-15 is a rust convertor, awesome stuff but a litle spendy. It is worth it though. Try a search using POR-15 as the key-word...you should get the main site quite quickly. If I recall correctly there are Canadian distributors for POR-15 and Princesss Auto carries Herculiner. I just saw it in their catalog for $199 (CDN $$) for 5 litres...
    http://www.princessauto.com
    Rene
  14. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah the guys that make Herc sell a clear top coat... but I have a sneaking suspicion that any old clear top-coat rattle can stuff would work and cost a lot less to boot... just MO. Anyone actually used it?
    J
  15. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
  16. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I got a question about Herculiner, I have been thinking about putting it on my blazer for a while now, I don't currently have any carpet and with the summers here in Texas it gets really hot inside the cab... How much does Herculiner stop the heat from comming in from the engine and trans, thanks for the info... and how much would it take for the entire inside... I have heard about a gallon and a quart???
    Sergio
  17. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    my 79 K5 took one gallan and a quart to do the entire floor pan and rear tailgate. I am going to get another quart for the sides behind the panels soon.
  18. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    My Herculiner story:
    I really hated the way my interior looked. There was dried "liquid nails" from a past carpet install, that black glue stuff the factory uses was everwhere, and the factory cardboard side panels were so wasted that i replaced them with sheetmetal (but they still didnt look right), etc.
    after months of lookin at it, i decided it was time to get busy, i totally stripped the interior and began the absolutely worst part of Herculiner which is prep. i wirebrushed and wirebrushed over a FULL weekend, masked the dash and other small areas and re-painted my roll cage red.
    the following weekend, i masked off the rollcage and other parts i didnt need/want the herculiner on and applied it over the course of a sunday. i coated the whole tub once, then went back and applied a second coat on the driver/pass/ and rear cargo areas. there really wasnt any reason to give the sides a second coat. i let it sit a full day, then after work went back and re-installed all my seats and stuff. i LOVE the way it turned out. I do have rubber floor mats (which are parts of a pick-up bedliner trimmed to fit the whole footwell), but i can tell you, it made a huge difference on the heat rtansferred from the exaust/engine to the floorboard. and like what was stated above, i can use the water hose and a scrub brush to clean up the interior. I AM VERY SATISFIED WITH HERC THUS FAR!!!!!!
    I will have pics up soon.
    rob
