Herculiner Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Oct 22, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I want to herculine my interior. At the same time I'm replacing the flimsy cardboard type side panels with plywood. My question is will it adhere to the wood as well as it does to the steel? Thanks in advance[​IMG]
    [​IMG]FUN WITH 31's![​IMG]
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Well if it will adhere to a 'Hootus' I'm pretty sure it will adhere to plywood! [​IMG]
    Good luck and wear gloves!
    Rene
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Go to the bathroom before you start.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  4. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    according to the directions "If wood texture is rough,it may not require preparation. for best results, abrade surface of wood before applying ploy coating.. Some ressure treated woods may need priming. If in doubt make a small test application first. Poly coating will bond to wolmanized treated wood without priming" There you go right from the horses mouth
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Don't have a cold either before you start....could get really bad when you cover your mouth!!
    SK-15
    J**P...it's whats for dinner!
    http://SK-15.coloradok5.com
  6. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    The "hootus" rears its head again! I knew those Ford guys were good for something. BTW, Duraback will stick to wood, if I remember right they make Herculiner. If you want to make use of the dead space behind the trim panels take a look at my web site. I used steel, but wood would work, too. You may want to consider getting it lined with the trim out. If you seal it up tight moisture will collect behind the panel and cause rust.
    Jim, '80 GMC.
    It's a Wheelbase thing, You're Jeep wouldn't understand!
    http://www.bigjbear.coloradok5.com
