here is a pic...need diagnoses..is this draglink angle too much ?
Discussion in 'The Garage' started by jakeslim, Apr 29, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I have bumpsteer after new springs were installed in front. From the 8 million post I read on bump steer(searched), I got the message that the draglink should be level. So tell me doc, is it curable?
  2. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Your angle looks about the same as mine does.
    I do have alittle bump steer but Im sure a lot has to do
    with no sway bar and a 6 inch lift.
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    well i installed the ord disconnect past weekend, and I have a 6 inch lift also.
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I am just wondering where your exstended brake lines are..hmmm? Also I have the same angle, but no bumpsteer because my blazer has bees holding down the floor for 2 years /forums/images/graemlins/1zhelp.gif
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    The extended brake lines are in my garage next to the d60 I still have to install. Just need a 3/4 ton rear to be ready for swap (and 8 lug rims).
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Play it safe and get yourself a Skyjacker 2" drop pitman arm. /forums/images/graemlins/thumb.gif
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    That's what mine is at. When stock, it's going down towards the pitman arm, so I guess go with K30's idea...
  8. supersize75
    Sep 27, 2002
    2,638
    I recomend buying the 8 lug rockcrawler rims from 4wp they were only like 225.00 shipped for 15x10 and I just got the 4.5 back spacing so no matter what they fit and no caliper grinding /forums/images/graemlins/thumb.gif
  9. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    do you have any degree shims between the axle and the spring perch? that also could cause bump steer.
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is hard to tell from that pic. A shot from the side with the wheel off would be better.
    You want the slope of the drag link to follow the slope of the front of the spring. With a stock spring (negative arch) that means sloping up from the pitman arm. Once you put a lift spring (positive arch) on it the draglink will have to slope down from the pitman just a bit. It is my experience that with a 4" lift a 2" pitman works for most trucks and with a 6" lift a 4" steering arm works for most trucks.
