here some more info on suburban...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Jan 12, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    ok well i guess he tore off 2 gears on the pinion gears..does that sound right? (i think) and he doesnt want to spend all kinds of money on new gearing..so would it be cheaper to buy a new axle? hopefully u understand
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Put this info in your original post...reply to bubba...with exactly what you said here. /forums/images/graemlins/smile.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what axle did mike have bad luck with ? whats happened exactly ?
    he is cool, so hope to help him in any way possible
  4. heavy4x4
    Aug 28, 2002
    3,270
    This is where the post started...should have just continued here
    As far as what to do...swapping out the axle is a better bet/less expensive in the long run, than new gears. A 14 bolt FF can be found for $150 in good, swap-in shape. Of course you'll need 8 lug wheels to go with it. And matching gears up front if it's a 4x4. Otherwise, if you don't want to mess with gearing/new rims, just get another 10 bolt /forums/images/graemlins/ignore.gif for $50 or a 14 bolt semi-floating (a little more $$ than the full-floating).
