Here we go again
Discussion in 'The Garage' started by wasted wages, Dec 17, 2003.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I'm sure this has been asked 100's of times before but I'll ask again,,,I have 40" tires on my k-5 with 8 inches of lift,will 44's fit with a body lift? the 40's already stuff into the floor pan (on the front axle)I have done major fender trimming because I'm trying to stay away from a body lift.If I put a 3" body lift and 44's won't I have the same problem stuffing the floor pan? Or are 12"spings my answer,,,
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    with body lift I forsee the same problem. A zero rate and moving the axle forward an inch should help that clearance issue. Nice K5 by the way.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Well let's see......if you add a tire that's 4" larger diameter, that means that the tire is effectively sticking out 2" further in every direction...
    ....which means that you now have 2" less clearance to the firewall than you have now......
    ....adding a 3" body lift means that you are "getting back" those lost inches of clearance....at least vertically. Unfortunately, when the front tire stuffs...it's going BACK as well as UP, so a body lift is probably not going to give you a true 3" inches of new clearance.
    How do you feel about trimming sheetmetal? /forums/images/graemlins/grin.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    he is trimmed his problem is tires contacting the firewall as I understand it.
  5. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    { A zero rate and moving the axle forward an inch should help that clearance issue}
    I'll admit my suspension knowledge is very limited,
    so how is this done? what is zero rate?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    a zero rate is like a block but it bolts to your leafpack so it doesn't have the dangers associated with a block. It provides an inch of lift without adding spring rate, aka a zero rate add a leaf. http://www.offroaddesign.com/catalog/Zero%20Rates.htm
    It also allows you to relocate the axle forward or back an inch or inch and a half.
  7. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    never knew these existed,,,will order today,,,,, /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif THANKS to all!!
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    haha you're welcome
  9. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I run 40's with 5" of lift. I moved my front diff forward 1.25" and the tires don't hit the floorboard/firewall area.
    Rene
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I plan to run 40s with 4" or 5" and moving forward an inch. We will see how my clearance goes.
