Here's a shot of a chopped up 14Bolt housing. Just because
Discussion in 'The Garage' started by cybrfire, Oct 16, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
    Here\'s a shot of a chopped up 14Bolt housing. Just because
    Not a lot of people will probably see it or ever have a need to do it. And some have asked about axle tube thickness. It's a full 1/2" where it enters the pig.
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Re: Here\'s a shot of a chopped up 14Bolt housing. Just because
    Now what are you doing with it?
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I guess burn through shouldn't be a problem if I weld to mine /forums/images/graemlins/confused.gif
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have posted up quite a few times that it was 1/2" but i never had a pic to prove it. I have cut up a 14FF housing before. The same day i cut a D44 and two 10 Bolts. Taking up too much room....
  5. divorced
    Jul 20, 2004
    5,115
    Did the 44 and the 10 bolt have the same tube thickness?
  6. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Thats a cool Pic, thanks man.
  7. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    yea i cut up my front d60, too cuz it was taking up to much room. Its about 1/2" too.
  8. divorced
    Jul 20, 2004
    5,115
    /forums/images/graemlins/rolleyes.gif
  9. readymix
    May 30, 2004
    6,706
    26
    Nope. The D44 came out of a really old and rusty chevy fullsize from a friends collection of junk and also had 1/2" tubes.
    The 10Bolt was the 7.5" ring gear sort out of a 90 or 91 s-10 truck. I don't really remember the tube size on it (3/8" /forums/images/graemlins/dunno.gif)but i know it was smaller.
  10. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
    I needed the tubes, spindles and hubs for a couple projects. One side will be jused to attach to a post in the corner of the shop I'm building this coming spring and it will get a nice boom attached to it. This way it will swivel and the plas and small welder will reach the whole shop. Course the boom will have two sections. The other side is gona be set up for a display for a couple things. Beadlocks, disc brake conversion, things like that at shows and swap meets. Not sure what I'm gona do with the center section.
  11. readymix
    May 30, 2004
    6,706
    26
    Display your DIY diff cover
    /forums/images/graemlins/thumb.gif
  12. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
  13. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I know what you mean, but cutting just takes too much time. Me and a couple of buddies dumped my D60 front in the trash can ... you never heard so much swearing as the poor garbage man lugged that sucker to his truck.
    Eric M.
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I cut up a bent 14bff. The tube walls have a taper and are thinner wall out near the spindle.
  15. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    no wonder why they are so damn heavy! /forums/images/graemlins/whistling.gif
  16. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Seal the ends, weld a plate to one of them and a leg and base to the other. Cut half of a stock diff cover off and bolt/seal it into place. use as a water pot with your bench grinder or whatever mounted on top of the steel plate /forums/images/graemlins/thumb.gif
  17. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
    I wondered if the thickness changed.
  18. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] I cut it out farther than the center section and I remember it being thinner than that.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] A Barstool would be an interesting idea. Plate with a cushion in place of the cover. Bolt the yoke to a stand and bam you have a 14 bolt bar stool /forums/images/graemlins/wink.gif. eh of course the pinion is offset so it would be a funky stool.
  20. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    14 Bolt Front. /forums/images/graemlins/whistling.gif /forums/images/graemlins/weld.gif
    /forums/images/graemlins/grin.gif
