heres one for thex files or the ...
Discussion in 'The Garage' started by boggerless, Mar 11, 2005.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    WTF?? is it files. anyway all the bulbs work but when i turn on the left turn signal only the front blinks. and when i turn on the right turn signal only the rear works???? like i said all the bulbs are new and work. thanks
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    maybe the connector came loose, that or the wiring might be bad. other than that i cant think of any other reason for it to do that
  3. boggerless
    May 26, 2003
    22,728
    96
    i checked the connections and bulbs. crazy eh???
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Check the wiring, just about anything could cause that. I found several broken wires in my quest to get the lights to work on my '76 K20.
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    check the rear harness thoroughly.. with them running down the frame they seem very prone to corrsion and shorts.. i found a couple spots that had welded themselves together.. also check the wheatherpack connectors in the back.. grounds too...
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    If everything else checks out you might look at the turn signal cam in your column.
  7. boggerless
    May 26, 2003
    22,728
    96
    it makes the blink blink sound in the column.:rotfl: i just rigged a ground today on a bumper support.its a 79 what color should that wire be? it was silver the eye broke off so i just used a bolt and nut with the old eye as a washer to hold the bare wire in place. just for the ground.
  8. boggerless
    May 26, 2003
    22,728
    96
    oh yea, i cleaned it to bare metal.:D
  9. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Hitch???
    Gotta trailer hitch??--check the plug for the trailer wires--I find a lot of problems there when lights start acting goofy...
    The directional switch is a possibility--but I'd check every wire,socket,grounds,and bulbs before taking the steering colum apart..the wires under the dash where they leave the colum might be partially unplugged at the connector--also where they leave the fuse box on the firewall side often get corrosion ....good luck..:crazy:
  10. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Dumb question but did you check yer relay?
  11. boggerless
    May 26, 2003
    22,728
    96
    yea, i got a hitch and i got rid of all the wires for it.sniped them off.:)
  12. boggerless
    May 26, 2003
    22,728
    96
    no i didn't thanks.:) i'll check it tommorow.
  13. boggerless
    May 26, 2003
    22,728
    96
    well tonight i checked the lights(easier when its dark) for the brake lights. anyway with the head lights on when i hit the brakes the right side works and the left side goes out. with the lights off both rears work? like i said i made a ground in the bumper support.WTF??
  14. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Bad grounds...
    Sounds like you still have no ground at one of the tailights,and it backfeeds into the other light when you apply the brake--both tail lights have a separate ground....maybe when you snipped the trailer hitch wire off,one of the was a ground for one of the taillights?....:crazy:
  15. primr87
    primr87 Registered Member
    Feb 15, 2005
    20
    placerville, ca
    my dad had a k5 that had a problem like that, it turned out to be because of a steering column swaped into the wrong model year truck. the PO did a bad job splicing wires.
  16. boggerless
    May 26, 2003
    22,728
    96
    they both need grounds eh. thanks bro.:D i'll do that in a minute here .
  17. boggerless
    May 26, 2003
    22,728
    96
    you were right bro. i grounded the left side and everything works. thanks:) :bow: :bow:
  18. boggerless
    May 26, 2003
    22,728
    96
