Here's one for y'all too figure out
Discussion in 'Audio' started by Z3PR, Mar 8, 2005.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Car is a 2000 Oldsmobile Alero GLS. Stock sound system. Bad ignition noise on AM when first started, or near power lines. Noise go's away after car warms up. Will have my JVC head unit installed in near future.
  2. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    check your ground from the antenna ( power antenna ) and check the grounds on the radio harness, also look for freyed wiring on the harness for the radio
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    That's your problem right there.
    Who listens to AM anyways? Didn't that go out with 8 track? :grin:
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My mother, that's who listons to AM. Everytime we go anywhere she has too hear her talk radio. Besides, I'm in SD where all the radio stations suck, both AM and FM.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Antenna in the glass. I'm just going too put my JVC KD-LX50 in it. The stock radio sucks goat scroat.
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    If the engine noise is present on any source.....CD, AM or FM then there's probably a deck grounding issue.
    It sounds like a bad antenna ground if it's only on AM....or maybe a loose or corroded connection where it plugs into the deck???
    Is this a factory setup, or is there more equipment installed? Bad amps grounds can cause this too....but again, you'd hear it on any source not just AM.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's 100% factory at the momment. Only hearing the engine noise on AM, and only for a 5 to 10 mins after start up or when near power lines. Noise usely go's away after 5 to 10 mins of driving.
    [​IMG] [​IMG] [​IMG] I belive the antenna is in the glass of the rear window.
  8. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    You sure that's not the defrost wires that you see in the rear window? Strange place to put an antenna if it is.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's got those also, but there are 2 wires running strait up as well.
