hesitation on accelaration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Dec 18, 2000.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    I HAVE A 84 K5 WITH 4SP 305. I HAVE A HESITATION ON ACCELARATION. WHEN THE CAR IS COLD AND UPON INITIAL ACCELARATION THE CAR HESITATES SLIGHTLY. WHAT SHOULD I CHECK FOR?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    is it carb or tbi?
    s.smith 77blazer lookin 4 mud
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    An '84 should have a carb unless it's been converted. Sounds like the accelerator pump is getting weak. Could be time to rebuild the carb. A new pump comes with the kit.
    http://ThunderTruck.ColoradoK5.com
  4. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    its most likely the choke. i had the same problem with mine i have an 85 4sp 305 now 350, i just adjusted the choke linkage when i first started it up until i found the best set up. you have to remember that a carb will not run as good as a fuel injected car when its cold, just give the motor 2 minutes to warm up before you go
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it is a carb i would agree with harryh3 replace the accelerator pump. mine did the same thing changed the pump problem solved
  6. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    Could be the accelerator pump or the choke pull-off.
  7. KENNY
    Dec 7, 2000
    292
    nyc
    I REBUILT THE CARB AND RECENTLY FIXED THE CHOKE WIRE WHICH HAD A SPLICE IN IT WHICH WAS KEEPING THE CHOKE LIGHT ON. THE CARB IS THE ORIGINAL QUADRAJET. COULD IT BE A VACUUM LINE?
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Just bite the bullet and have your carb overhauled, that will immediately rule out several problems. Then look over that choke, see that its getting proper voltage and what the mixture is set for. If it stinks like hell, you're rich and if not that then ummm, well I dunno I've only had it to rich. Then check all your vacuum lines for good measure, you know...cracks, seal, etc. You might also want to check your air inlet of your air cleaner, there is a tube off the exhaust manifold that sends heat up there to adjust how far open it is in cold weather. It should stay closed when its really cold out to keep cold air out until the engine is warm. Does the engine idle smooth also, you could have some ingition trouble but it wouldnt have power all the time, not just when cold.
  9. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    try ur intake gasket mine had hesaitation to then i found out it was the intake gasket and fixed it then no more problems just look and see might be the problem ....
  10. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    check your timing...just just replaced my distribitor because of the same thing...u might what to try the cap and rotor first but my prob was the HEI distribitor
    "whoo my new pic is on the photo page...check it out!!"
