Hesitation on hills
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Feb 10, 2003.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I've just started noticing on some steep hills, passes, my truck has been hesitant. I'll be charging up a hill about 2500-2700 rpm, i've got 4.10's and 35's. And every once in a while the engine surges, like it's running out of gas. Could this mean I need to replace my fuel filter? Or would it be the cause of something else. It only really occurs when its under load up a hill, just more sluggish then usual. /forums/images/graemlins/truck.gif
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    cold be but id more likely blame the carb
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I would start by changing the fuel filter, couldnt hurt to change it anyway. If that doesnt fix it then check out the carb. It might also be that there isnt enough gas in the tank and it is moving away from the pickup tube.
  4. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    I had a full tank when this was happening, also Im about to put a new intake manifold on. SO when I got the carb off, what should I be looking for? /forums/images/graemlins/truck.gif
