hesitation problems....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StageZ, Feb 10, 2002.
  1. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    I breaking in my new 383 stroker and am having a anoying hesitation problem... I am running a edelbrock 600(the one I ran on my old 350) and have about 75 miles on the new engine... Once I touch the gas she seems to want to bog then picks up real nice...it happenes more when she is cold... is this a carb problem? what should I check? if I let her drop to idle and then give her some gas she starts to go, puts once and picks up... any help will be much appreciated.... thanks in advance....
  2. BigJim90
    BigJim90 Newbie
    Feb 2, 2002
    Seattle WA
    Sounds like timing problems to me. I had the exact same symptoms on my k5, and finally narrowed it down to the timing. After I adjusted the timing, throttle response was much crisper. It also may be fuel line related (filter?).
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    check base gasket of carb. could have vacuum leak
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Choke or heat stove possibly. If you have a 383, it sounds like you like to hot rod and may have an open element cleaner. Ditch it. Thats right, they're a joke. The problem is that they have no temp regulation. They suck in hot dense air at operating temp or extrememly cold air in the winter when warming up. The stock air cleaner has a tube that goes off its intake and to the front clip, which sucks in cold dense air. Sorta like a cold air induction setup. In the winter it has a heat stove comming off the manifold which sucks in warm air to help when the air is very cold. This all regulated by a little valve on the air cleaner.
    If you don't have the open setup, then ignore my preaching.
    Choke is always worth a shot in cold conditions.
    <a target="_blank" href=http://www.geocities.com/bigkern76>The Blazer Boy Page</a>
