Hey 10 bolt guys...i need some quick help
Discussion in 'The Garage' started by Chaz88K5, Jan 18, 2003.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    ok i took a job to change the axle seals on a 84 blazer from a guy at work...i figured it would be easy considering it was spose to be a open diff...but when i cracked the cover i found a gov lock...now keep in mine i have never seen one nor worked on one...so my problem is....how do i get the damn C clips out...i cant get anything in there to get to em..if someone could help please...i got it apart right now and need to get it done so i can start workin on my own truck /forums/images/graemlins/thumb.gif
  2. Chaz88K5
    2,979
    Stockton/Lodi CA
    come on...can anyone help me out here /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's just like on an open diff. You have to pull the center pin before the axles will slide in far enough for the C-clips to fall off. There's a steel block in the center of the diff, that the shaft slides through. You have to take that block out, and the spider gears might have to come out as well, to have enough clearance to get the block out of there.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Its been awhile since I'e done this but heres what I rember.
    Pull the pinion pin part 3/4way out. careful not to let it fall inside the diff
    rotate the carrirer till the pin hits the top outside of the housing.
    You should be able to see the C clips between the thrust block in the very center and the spyder gears
    You have to use a thin screw driver to move the C clips around so the open end point inside of the diff.Other wise you cant push the axel in far enough to get them out.
    When you get the open end pointing in Push the axel in then you can pull the C clips out.
    Hope this helps
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What Thunder said. I had to do the same procedure a couple of months ago on the one I got from <font color="orange">rockinK5 </font color>.
  6. Chaz88K5
    2,979
    Stockton/Lodi CA
    got almost all of it done..was changin the brake pads while i was in there and gettin ready slide the drum back on and then i was like oh crap i put the shoes on backwards /forums/images/graemlins/rolleyes.gif so i pull it all apart again on that side and go to put it together again and tryin to pry a spring in palce and the bastard slips and come flyin back and jabs about an 1/8 inch into my cutical and nail...it hurts like a sob and my thumb is numb right now...damn /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Spend $10 on a real pair of brake spring pliers and your hand won't be anywhere near the springs as you remove and install them. /forums/images/graemlins/deal.gif
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    it hurts like a sob
    Pain lets you know you're still alive!! /forums/images/graemlins/rotfl.gif
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
