Hey 14 bolt Gurus where are ya?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4GUNZ4X4Z, Mar 19, 2002.
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I just bought a 14 bolt and the guy I got it of off said I needed to tighten down the center bolt on it. Well when I went to go do this 2 of the 8 outside bolts were loose. When I went to put the shft back in and tighten down the 8 outer bolts the 2 that were loose wouldnt bolt back in. They seemed to be stripped. What can I do about fixing the 2 that seem to be stripped? Can I get longer bolts or what?
    Also whats the best way to tighten down the center nut after you take out the shafts?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I don't see why you couldn't helicoil the bad holes...
    Rene
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I dont see why not either, especially since the other 6 are in there tight. And then even more so if the 2 loose ones were not right next to one another. This would help distribute any loads on it through out the 2 on either side of the helicoiled bolt. Go for it. You really dont have anything to loose.....but an axle /forums/images/icons/laugh.gif j/k Just do it! You can always get another hub, or tap it out to the next "fairly" common bolt size and have 2 sets of bolts....and sockets for that wheel.
