Hey Boys chev350 Q???????
Discussion in 'The Garage' started by looloozu, Nov 28, 2006.
  1. looloozu
    looloozu Registered Member
    Oct 30, 2006
    26
    canada
    Ok so i have a chevy 350 with a set of headers and a quadrajet carb. The motor wont stay running and bucks and backfires out the carb. or shoots a flame out the carb. I changed the carb to another one i know works off another 350 i have and the same problem. so its not the carb. I have played with the distrib and no luck. i had a friend look at it and he seemed to think it may need new plugs,wires,buttom and cap. when the motor dose get started it seems to run just dosent idle. so im not sure if its the timing. any pointers would be good!!! would wires and plugs make it buck and backfire out the carb???
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Check you timing, and make sure your wires are connected good and you have the firing order correct. Is this something that just started happening for no apperent reason?? Is this a rebuild or motor swap? What have you done to this engine? Did you just happen along a crappy running motor?
  3. looloozu
    Oct 30, 2006
    26
    canada
    its been a good working motor never any probs. its been in the same truck for a year or so. it sat for a few weeks over the summer when i installed a liftkit. before that it ran great. it just seemed to have problems running one day and overnight it started this stuff. would bad plugs and wires back it backfire like that?
  4. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    the only time ive ever seen an engine backfire out through the throttle body or carb was with the distributor 180 degrees out of time.
    its weird that this started after a lift kit install, or with the truck just sitting.
    one thing to check is get a can of gumout arosol (sp) spray degreaser, and start the truck by spraying that into the carb, and keep spraying to see how the truck idles, then stop spraying and see if the truck bucks and dies.
    depending on how long the truck sat, the fuel could have varnished and pluged up some venturi or something. i suppose its possible that a lean condition could cause a backfire, but its most likely the timing.
    if you would like a run down on how to set the timing id be happy to give it a shot over the internet. also if you can, review how to set your idle speed screws and jets on the carb. thats something im not fully up to speed on but im sure someone here can help ya out.
  5. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    oh and another thing it might be, the distributor control module, its a small peice located under the rotor. its an annoying little bugger that can cause all kinds of driveability problems that confused the hell out of people. its only like 50 bucks. so it might be worth replacing just as a check ;)
  6. deadtoyou
    deadtoyou Registered Member
    May 22, 2004
    36
    spokane
    Same thing happened to a friend's 454, pretty much overnight. sucked a valve, got the heads rebuilt and now runs like a champ.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    do a compression and leakdown test while you're at it, see what kind of condition the motor is really in.
  8. looloozu
    Oct 30, 2006
    26
    canada
    ok so check the
    timing
    compression test
    plugs and wires
    rotor but and cap
    anyone think of any other stuff to test. remeber this carb just came off a working 350 less then 20min before it went on this motor. so i know it works fine.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    but it doesnt sound like a carburetor problem... would you check your battery if your tires were going flat?
  10. looloozu
    Oct 30, 2006
    26
    canada
    yea i know its just ppl keep telling me its my carb dumping too much gas.
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    ^^Check these and get back to us
  12. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    well..... actually, swapping a working carb from another engine wont always work, the carb settings may be different depending on engine size, cam, head flow, fuel demands.... etc. etc. but if its still doing the EXACT same thing, and the engines are pretty similar as far as cam specs and size and whatnot, then yeah you can probly ignore the carb as the cause.
  13. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    vacuum leaks can be a biatch.:mad: Add that to the check list.
  14. looloozu
    Oct 30, 2006
    26
    canada
    ok so i got a new set of plugs and wires. new rotor cap and button. still no luck. BUT i turned the distrib all the way counter clockwise. I think thats advansing it. and she starts and seems to run no backfireing out the carb. its still fussy but alot better. it seems if i could turn the distrib just alittle more it will be good. Is that mean maybe i jumped a tooth or something???
  15. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Did you ever remove the distributor. It shouldnt jump a tooth all on its own.
  16. looloozu
    Oct 30, 2006
    26
    canada
    no i have never removed it.
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stretched timing chain , or wore out factory plastic coated cam gear could make the symptoms too .
  18. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Ok do this as a test. Move your plug wires over one terminal on the cap in the same way you were turning it that got it running better. This will be the same as turning the dizzy. You may then have to turn back the dizzy because of how much this is moving the advance/retard. If you do this and can turn the distributor and get it run good then thats a start. Then we look into cam gear problems or timing chain stretching or jumping a tooth.
  19. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    im still of a mind that somehow, someone moved that distributor, my IROC had 23 degrees of slack in the timing chain, and still ran just fine. the only time ive seen fireballs like that coming out the throttle body or carb was with the dizzy 180 out, or the wires being crossed on the distributor control module. ive youve turned the dizzy as far as you can and its better but still not running great, then somewhere, somehow someone moved that dizzy and it needs to be reset to the number one cylender at top dead center.
  20. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Ive had fireballs shoot out of carb when trying to start and my timing and carb adjustments are fine. Truck had been sitting for a while and didnt want to start. Cranked, stuttered, tried to start and :angry1: out carb. Good thing I had air cleaner off.
