Hey DBlazer
Discussion in 'Audio' started by Cusm, Mar 23, 2001.
  1. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    I am about to do the side panel sub set up, I am thinking at only using one sub and was considering putting it behind the spare tire (to add to security, cut down on its visibility). Any problems this might create? I know bass is not dependant on location, but I don't know if the spare in front would cause any problems.
  2. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    hey could you send me a description or something of how you put the sub in the side panel. i would really like to do this but i dont think that there is clearance for a sub is there? let me know if you would. i am very interested. pics would be good if you have them. thanks.
  3. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Look at the threads covering it here in the audio section, about 4 people have done it, w/ pics. There have been a couple of different subs used and spacing for them.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I am not the one to answer to question as to whether the sub behind the spare will cause problems, but can answer the rest of your questions. There is aproximately 3.5" of space behind the side panels. Whether or not your sub will fit depends upon the depth of the sub. If properly sealed, there is enough airspace to accomodate most 10"-12" subs.
    Take a look at my web-site http://www.derf00.coloradok5.com or http://www.BlazzinOr.coloradok5.com
    The difference in these two installs is the thickness of the sidepanel materials, Frank used two 10's, I used one, and Frank put a spacer behind his subs. As you can see, you wouldn't know it was there if you didn't know it. I am running 1 10" sub on a RF 200a mono amp. If you turn up the volume, the single sub will shake ever loose part on your K5.
    Good luck, hope this helps.
    I
    Derf00
  5. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Sorry it took so ong to reply, No, putting the woofer behind the spare wont cause any problems!!! It should work just fine. Just make sure to check the excursion (how far the woofer moves out) so it doesnt rub the carrier.
    <A target="_blank" HREF=http://dblazer.coloradok5.com>http://dblazer.coloradok5.com</A>
