Hey DepDog and Shawn
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dpearson, Jul 20, 2000.
  1. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    Hey Guys,
    I just wanted to say you both have excellent articles at the off-road website and I burned a copy of the Dana 60 Rebuild and install as well as the spring perches and custom grill. My question is, Have either of you done a 14bolt swap which required moving spring perches and shock mounts? Any help would be greatly appreciated.
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Thanks! I've done the 14 bolt swap with a 1980 GMC 3/4 ton 4x4. Everything bolted up. The spring perches and shocks mounts where fine and did not have to be modified. The only hitch was the e-brake cables. 84-91 3/4 ton Suburban backing plates should fix that problem.
    Shawn
